ASA with Nokia VPN auth - CRACK
Hello!
Do anyone have successful experience with CRACK authentication on ASA? tell pls versions and coonfigurations.
on asa version 8.0.4 authentication fails on certificate verification stage.
debug after successful ike policy verification:
Mar 15 19:18:09 [IKEv1]: IP = 192.168.0.169, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + CERT_REQ (7) + VENDOR (13) + NAT-D (130) + NAT-D (130) + NONE (0) total length : 403
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, processing ke payload
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, processing ISA_KE payload
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, processing nonce payload
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, processing cert request payload
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, processing VID payload
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, Received Nokia Client Vid VID
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, processing NAT-Discovery payload
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, computing NAT Discovery hash
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, CRACK processing is initiated...
Mar 15 19:18:09 [IKEv1]: IP = 192.168.0.169, Unable to find the requested certificate
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, CRACK processing is completed...
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, IKE MM Responder FSM error history (struct &0xc9118840)  <state>, <event>:  MM_DONE, EV_ERROR-->MM_CRACK_DONE, EV_ERROR-->MM_CRACK_BLD_MSG4, EV_UPDATE_CERT-->MM_CRACK_BLD_MSG4, EV_DO_CRACK-->MM_BLD_MSG4, EV_TEST_CRACK-->MM_BLD_MSG4, EV_SECRET_KEY_OK-->MM_BLD_MSG4, NullEvent-->MM_BLD_MSG4, EV_GEN_SECRET_KEY
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, IKE SA MM:50b15acd terminating:  flags 0x0100c002, refcnt 0, tuncnt 0
Mar 15 19:18:09 [IKEv1 DEBUG]: IP = 192.168.0.169, sending delete/delete with reason message
Cert on ASA is signed and CA cert is available on the nokia E51 phone
Mathieu Hofstra Thu, 02/03/2011 - 06:47
I have the same problem with this CRACK type VPN and Nokia MobileVPN
software. I have the same error "Unable to find the requested certificate". If I understand correct
ly it's saying that the asa cannot find the certificate. This is quite strange because the asa shou
ld issue a certificate to the client, not the other way around....
Is there someone who has a working remote access vpn with CRACK authentication?
Is it possible to test such a VPN type with the Cisco VPN client software?
