How to disable ipv6 ACL-Rules in ASDM?
Mar 16th, 2010
is it possible to disable the ipv6 Access-List-Rules in ASDM? I have about ten interfaces, that are all double-displayed with an ipv6 implicit deny rule. I don't need this rules and it is a very confusing view of all access rules with the unneeded ipv6 rules. ipv6 is disabled on all interfaces.
Can anyone help me? Thanx!
Federico Coto F... Tue, 03/16/2010 - 09:24
This is interesting, I don't see anyway to remove an implicit rule.
You can remove any line on any ACL, but the implicit ACL rules (this applies for IPv6).
Anyway i will try to see if there's a way to do this.
Federico.
mjonesydl Thu, 04/11/2013 - 02:33
Two years late, but I was looking at the same thing.
In ASDM version 6.6 (at least that is what I have in front of me), at the bottom of the middle pane that displays the rulesets, is an 'Access Rule Type' section, where you can specify IPv4 only, IPv6 only or both.
Cheers
Martyn
