03-16-2010 04:07 AM - edited 03-14-2019 05:26 AM
When utilizing IP soft phones -
are switch ports setup just as they are for standard IP phones with both voice and data vlans?
Solved! Go to Solution.
03-16-2010 04:25 AM
The softphone will not use the voice VLAN, so whilst you would normally have a standard/consistent edge port config which would likely include a voice VLAN, you don't NEED it as such.
You would however want to consider your configuration for QoS; if you are using trust-cos or trust-ciscophone then you will want to either switch to trust dscp, or (better) a policed input service policy. If you're not sure how to do it, using auto qos trust cisco-softphone will configure a service policy that will work well for both IP Phones and softphones.
Aaron
Please rate helpful posts...
03-16-2010 05:16 AM
Just click the stars on the bottom of the reply, there's also somewhere you can mark a question as 'answered'... not had cause to do it myself since NetPro was updated..
Aaron
03-16-2010 04:25 AM
Aaron
03-16-2010 04:45 AM
Thanks Aaron,
Interesting - thanks for the quick response. On that note how does one rate answers?
03-16-2010 05:16 AM
Aaron
