03-16-2010 04:57 AM - edited 03-10-2019 05:00 PM
I've been configured my device 6506-9 with TACACS+ server authentication:
enable password 7 1414131F5C542638
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login no_tacacs enable
aaa authentication ppp default group tacacs+
aaa authorization exec default group tacacs+ if-authenticated none
aaa authorization network default group tacacs+
aaa accounting update newinfo
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa session-id common
ip tacacs source-interface Vlan4
tacacs-server host 10.4.X.X key 7 1 044A1E030D345F4D080A554745
tacacs-server directed-request
tacacs-server key 7 12081012101E1F072B3874786475
interface Vlan4
description Servers
ip address 10.4.X.X 255.255.0.0
no ip redirects
standby 1 ip 10.4.X.X
but when I tried to access the device only uses authentication local but not uses TACACs (with username/password defined) it can be an error in configuration? in the other devices of network this works properly, only it's wrong in Cat6506-E
device# telnet 10.1.1.3
Trying 10.1.1.3 ... Open
User Access Verification
Password:
Thanks!
03-16-2010 08:02 AM
You have configured the default authentication method to use TACACS+ with a fallback of line password.
Since you are being prompted for the line password, it appears that the router can't contact the TACACS+ server.
Please enable these debugs, recreate the problem and show us the output:
debug aaa authentication
debug tacacs
You will also want to make sure that you can reach the TACACS+ server when sourcing packets from VLAN 4.
03-22-2010 10:31 AM
from 2 Cat6509 that form the core of the network, I can ping the TACACS server (from other network equipment, TACACS works without problems):
Core1 # ping 10.4.2.33
Sending 5, 100-byte ICMP Echos to 10.4.2.33, timeout is 2 seconds:
Success rate is 100 percent (5 / 5), round-trip min / avg / max = 1/1/4 ms
Core1 # ping
Protocol [ip]:
Target IP address: 10.4.2.33
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.4.1.253
Type of service [0]:
September DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose [none]:
Sweep range of sizes [n]:
Packet sent with a source address of 10.4.1.253
I completed the debugging that you've recommended (attached file).
Thank you very much for your reply.
03-22-2010 11:09 AM
Make sure ACS have IP address of VLAN 4 listed under aaa-clients.
~JG
03-23-2010 03:06 AM
The IP management of all network equipment is in vlan1 with IP range: 10.1.XX/16
The TACACS server IP is on VLAN 4 with addressing 10.4.XX/16.
In the TACACS server is allowed the full range of VLAN1 to authenticate, and all network equipment properly do, except the CORE devices...(Cat6509)
Thanks!
03-23-2010 07:16 AM
In the debug output we see:
Mar 22 17:14:58: TPLUS(00000061)/0/NB_WAIT/524FDA08: Started 5 sec timeout
Mar 22 17:14:58: TPLUS(00000061)/0/NB_WAIT: socket event 2
Mar 22 17:14:58: TPLUS(00000061)/0/NB_WAIT: wrote entire 51 bytes request
Mar 22 17:14:58: TPLUS(00000061)/0/READ: socket event 1
Mar 22 17:14:58: TPLUS(00000061)/0/READ: Would block while reading
Mar 22 17:14:58: TPLUS(00000061)/0/READ: errno 254
Mar 22 17:14:58: TPLUS(00000061)/0/524FDA08: Processing the reply packet
That suggests a mismatched TACACS+ shared secret, please check into this.
04-17-2013 02:15 PM
I, too, am having issue.
Solutions attempted, but still failed:
1. entered tacacs key again
2. restarted Cisco ACS 5.2 server
3. added "ip tacacs source-interface" command
Here's the original post I created. I didnt know what to search originally, so created a separate topic/thread.
https://supportforums.cisco.com/thread/2203407
Thank you,
Adam
