cisco 7911 pc port settings
Aaron Harrison Tue, 03/16/2010 - 05:33
  • Community Spotlight Award,
    Member's Choice, May 2015
You can do it from the keypad, though I know that's not what you want! I've seen scripts for configuring backgrounds by pushing key presses to the phones, but how relable it would be for something as important as this is difficult to say.
What I would say is that I really only see problems with speed/duplex settings at customer sites where they have taken to setting speed and duplex manually - it's far more common for someone to mis administer a phone or PC  that for negotiation to fail these days, and I see very busy network people wasting time setting/unsetting switch ports and messing with NICs on these sites...
Aaron
Aaron Harrison Tue, 03/16/2010 - 12:29
In an effort to be marginally more helpful - at http://www.myvoipsource.org/open-source-tools/ there is an app for controlling remotely the buttons on the phone for this sort of thing.
I've had some good experience of stuff on this site, but some stuff can be a little out of date...
Aaron
Please rate helpful posts..
thanks for that. Yes its not ideal doing it from the phone itself
so I was hoping for an enterprise solution.
A lot of our devices were fixed 100/full so the phones being on auto is causing them all to connect half/100. Its either a case of networks changing all the phones or desktops doing all the pc's... whichever is the simpler!
Aaron Harrison Wed, 03/17/2010 - 04:14
I would say do the PCs, then never do it again... rather than do the phones and still be messing with these settings five years from now...
In answer to the other question - sorry, no - not aware of a newer version. I take it you tried it and it didn't work?
Aaron
Related Content
