Auto QoS on 4507R-E
arudolph_emd
Hello -
I have a 4507R-E chassis with Supervisor IV running IOS 12.2(50)SG.  I am trying to configure "auto qos voip trust" on some of the uplink ports.  When I try to configure it on a port that is in a channel group, I get the error "AutoQoS Error: AutoQoS can not be configured on member port(s) of a port-channel".  I have also tried configuring it on the channel interface, but it is not an available command under the channel interface.  Is there a way to do auto qos on the channel interfaces or their member ports or does it have to be configured manually?
Andy
12 Replies 12
smolz
Level 4
Level 4
i am in the same boat here.  Any word on this?
Ganesh Hariharan
Hello -
Andy
Hi Andy,
Check out the below Bug ID CSCsv03316
Symptom:
AutoQoS cannot be configured on member port(s) of a port-channel.
Switch#sh runn int fa 3/1
channel-group 2 mode on -- Port in etherchannel
Switch#conf t
Switch(config)#int fa 3/1
Switch(config-if)#auto qos voip trust
Conditions:
This problem is seen in 12.2(40)SG (and later releases) on K2 based supervisors such as SupV-10GE.
The problem is not seen in 12.2(37)SG.
Workaround:
Do not use Auto Qos. Take the configuration that would be generated by Auto Qos and apply it manually to a port.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
So on my 4507 with SupVI the other trunk links I have configured have generated the following commands:
interface GigabitEthernet1/3
auto qos voip trust
switchport mode trunk
service-policy input AutoQos-VoIP-Input-Cos-Policy
service-policy output AutoQos-VoIP-Output-Policy
Would I then apply the 2 service-policies to each of the 4 interfaces in the port-channel or to the port-channel itself?
auto qos voip trust
As per the workaround you need to apply those policy individually on physical ports of the etherchannel.
Hope to Help !!
Ganesh.H
Here is what I get trying to enter the commands:
router(config-if)# service-policy input AutoQos-VoIP-Input-Cos-Policy
% A service-policy with non-queuing actions should be attached to the port-channel associated with this physical port.
router(config-if)# service-policy output AutoQos-VoIP-Output-Policy
router(config-if)# interface Port-channel1
% A service-policy with queuing actions can be attached in output direction only on physical ports.
Was this resolved?  I have the same issue as the person in the previous post.
Is it this case resolved because i also face same problem need help!!!!!!
thanks
-Thor
No, it was not resolved. I need this resolved as well. Please post back if you get a solution.
Shashank Singh
Hi Andy,
'auto qos voip trust' is a command to prioritize traffic on an interface connected to an IP Phone. Thats the reason this command is not supported on etherchannels.
If traffic from your IP Phone is already marked, you can just trust the marking by 'qos trust cos' on the uplinks which should take care of sending the traffic to the correct queue on the core switch.
However on etherchannels, you can still go ahead and apply the configuration generated from using 'auto qos voip trust' on a non bundled port.
Following steps worked for me:
1. 'sh run int gx/y' for port you want to bundle
2. bundle those ports with 'channel-group <#> mode on'
3. 'sh policy-map' to check the name of the policy map generated using auto qos voip trust   (for me the policy map was 'autoqos-voip-policy')
4. go to config mode on the physical-ports, and do
service-policy input autoqos-voip-policy
service-policy output autoqos-voip-policy
Following is sample configuration from a lab switch:
WS-C4507R#sh policy-map
  Policy Map autoqos-voip-policy
    Class class-default
      dbl
! sample port having auto qos voip trust configured
interface GigabitEthernet7/1
qos trust cos
auto qos voip trust
tx-queue 3
   bandwidth percent 33
   priority high
   shape percent 33
end
interface GigabitEthernet7/2
channel-group 1 mode on
end
interface GigabitEthernet7/3
end
end
Hope this helps,
Shashank
Please rate this answer if you found the content useful
Ok, I'll explain the issue again, as your solution does not seem to work.  The AutoQos policy that you switch generated, must be different than ours.
The AutoQos policy won't apply to the etherchannel, even when you place already created AutoQos policy on the interface using the 'service-policy' command.  If you attempt to place it on the Etherchannel/port-channel, it tells you to place it on the physical port.  When you try to place it on the physical port, it tells you to place it on the port-channel.  It's a circle.
4506_SW#sh policy-map
  Policy Map AutoQos-VoIP-Input-Dscp-Policy
    Class AutoQos-VoIP-Bearer-Dscp
      set qos-group 46
    Class AutoQos-VoIP-Control-Dscp26
      set qos-group 26
    Class AutoQos-VoIP-Control-Dscp24
      set qos-group 24
  Policy Map AutoQos-VoIP-Input-Cos-Policy
    Class AutoQos-VoIP-Bearer-Cos
      set qos-group 46
    Class AutoQos-VoIP-Control-Cos
      set qos-group 24
  Policy Map AutoQos-VoIP-Output-Policy
    Class AutoQos-VoIP-Bearer-QosGroup
      set dscp ef
      set cos 5
      priority
     police cir percent 33
       conform-action transmit
       exceed-action drop
    Class AutoQos-VoIP-Control-QosGroup26
      set dscp af31
      set cos 3
      bandwidth remaining percent 5
    Class AutoQos-VoIP-Control-QosGroup24
      set dscp cs3
      set cos 3
    Class class-default
      dbl
Single trunking port to router with 'auto qos voip trust' applied:
interface GigabitEthernet2/1
switchport trunk allowed vlan 100,500
auto qos voip trust
spanning-tree portfast trunk
Ports inluded in etherchannel:
'service-policy input AutoQos-VoIP-Input-Cos-Policy' (when I enter that, I get the following below)
'service-policy output AutoQos-VoIP-Output-Policy' (when I enter that, I get the following below)
interface GigabitEthernet1/4
switchport
(well, I tried putting it on the physical port above, and the error, which is noted above, says, it must be applied on the port-channel.  It is a loop).
I facing exactly which show at above post.Really Need help!!!
-thanks
Thor
I have a 4507R-E lite with sup 6L-E and having problems with QoS commands, is the QoS commands different in this than a 4506?
If some one pls point me to a document on QoS for the above model 4507R-E lite with sup 6L-E, i looked at the enterprise QoS SRND and also the medianet QoS they all reference the 4500 series nothing in specific for this. i tried the same commands used on 4506 but they dont work on the 4507R-E.
any help is appreciated and thanks.
Prabhu
