CSS Show summary command question
Mar 16th, 2010
When I issue "show summary" within the owner of SPOT-WT-PROD-EXT (please excuse the names I didn�t pick them)
I get the below results. my question is why does content web-servers have 3.1 mil + hits when the other two content rules have the same number of hits but far less. Before I issued the show summary command I typed "zero all" to bring the counts to zero. any thoughts?
Owner                               Content Rules                         State     Services                             Service Hits
SPOT-WT-PROD-EXT         SPOT-WT-PROD-EXT-A          Master    ACE-SPOT-WT-PROD        2816
                                        SPOT-WT-PROD-EXT-B           Master    ACE-SPOT-WT-PROD        2816
                                        web-servers                             Master    ACE-SPOT-WT-PROD       3162510
dtochilovsky Thu, 04/15/2010 - 15:03
Looks like it is something in the way the services are used in the content rules. Can you provide the configurations for the contents (web-servers and SPOT-WT-PROD-EXT-A, SPOT-WT-PROD-EXT-B)?
Gilles Dufour Tue, 04/20/2010 - 02:40
The show summary gives you info about traffic coming in.
The CSS is not responsible if it gets more traffic for one rule vs another one.
You should check upstream ....or it might be the nature of the application....the last rule attracting more users...or generating more connections.
