Joe Clarke Tue, 03/16/2010 - 10:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is very difficult to do.  It was made a bit easier in DFM 3.2, but prior to that, you need to first adjust the priorities of your groups under DFM > Configuration > Polling and Thresholds > Setting Priorities.  Then, apply your changes, then use the View button under Managing Thresholds to see what devices were actually matched.  In DFM 3.2, there is a new Preview button in the Managing Thresholds screen which lets you see how the group will match prior to setting priorities, and applying changes.
