ASA5505 Drops Easy VPN Remote Connection to ASA5520
Mar 16th, 2010
ASA5505 at remote site drops easy VPN remote connection to ASA5520 at HQ. ASDM to 5505 device and find the Enable Easy Remote check box is unchecked. I recheck box and the connection is restored. This has happened 3-4 times now. I make sure to do a wr mem after exiting ASDM. Any explanation as to why this should be happening ? Running ver 8.2(1) on 5505.
StanDamen Mon, 03/22/2010 - 03:19
We will need more information to help you with this:
1. Post the configuration logs
2. Turn on ASDM logging (if it is off) and tell us what it logs when the connection gets thrown out
The information you provided doesnt really give us any starting point
HTH,
Stan
