NEXUS 7000 vPC loop when enabling DHCP feature
Mar 16th, 2010
Hello All,
I'm setting up a new data center with two Nexus 7000 and one Nexus 5000 . The 5000 is connected to both 7000s using a vPC ( all is done by the book and the vPC is working very well).
If I enable any VLAN interface on the 5000 then I start getting a duplicate IP address warning ( the IP address of the VLAN interface ) :
%ARP-2-DUP_SRC_IP:  arp [2783]  Source address of packet received from 000d.ecf2.8dbc on Vlan90(port-channel4043) is duplicate of local
It seems that the gratuitous arp requests for the local address are getting looped back to the 5000 over the vPC !!
I noticed that the issue only happens when the DHCP feature is enabled on the Nexus 7000s ...
Any help is really appreciated ....
Jerry Ye Tue, 03/16/2010 - 13:43
  • Cisco Employee,
What version of NXOS are you running?
jerry
Jerry Ye Tue, 03/16/2010 - 14:06
  • Cisco Employee,
Sound like you are hitting bug ID CSCsx69941. The fix will be in 4.1(5) or 4.2(1).
HTH,
jerry
mrahman71 Tue, 03/16/2010 - 14:26
Upgrading to 4.2 (4) fixed the issue ... Thank you Jerry for your help
