[UC520] Cisco Unity Express
Answered Question
Mar 16th, 2010
Dear All,
Is it possible to change/upgrade my revision number in the Cisco Unity Express ? If "Yes" could you tell me how ? I want to upgrade it from 3.1 (current) to 3.2 in example.
The current situation:
UC500-CUE# show version
Revision:3.1 (pvr 8083 0031)
UC500-CUE# show software versions
Cisco Unity Express version (7.0.3)
Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2008 by Cisco Systems, Inc.
Components:
- CUE Voicemail Language Support version  7.0.3
Thank you !
Correct Answer by Darren DeCroock about 7 years 3 months ago
Yes, you can update CUE.  The newest software packs have upgrades for IOS, CME, and CUE...
Newest version: Software Pack 8.0.1
https://supportforums.cisco.com/docs/DOC-9829
Make sure you choose the correct file for your UC5xx product..
Thank you,
Darren
Overall Rating: 5 (1 ratings)
Velin Tsekov Mon, 03/22/2010 - 10:24
I read this information here http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps5520/prod_qas0900aecd806a79c9_ns296_Networking_Solutions_Q_and_A.html. The important info is that Cisco says that we need revision number 3.2 version to support Turkish language on Unity Express. So can you confirm that If I update Unity Express with software pack 8.1 the revision number will be updated to 3.2 ?
Thank you in advanced !
