I have 2 Arrowpoint CS-800 (cisco CSS 11800) They are both booting up fine but I can't telnet to them even with console port
Mar 16th, 2010
I have these units looks like they are booting up fine but I can't communicate with them. I got setup pdf files and using the com port settings but I can't reach them. some times I don't get any response at all some times I get some ASCII characters. I used port settings :
Baud Rate - 9600
Data Bits - 8
Flow Control - none
Parity - none
Stop Bits -1
still no communications, I'm using regular blue console cable cisco uses. can anyone help?
Reza Sharifi Tue, 03/16/2010 - 11:58
  • Cisco Designated VIP,
    2017 LAN
Hi Ike,
You setting looks correct.  Try changing the baud rate to 38400 and see if it helps.  if that does not help try a different application i.e terra term or Secure CRT, etc... to access the devices and see what happens.
Reza
Tharak Abraham Wed, 03/17/2010 - 01:01
  • Bronze, 100 points or more
com1 or com2 ?
please check the device manager on your lappy or pc for this ?
If this is ok and the settings is as per you said...the culprit should be the cable !
ikek Wed, 03/17/2010 - 09:58
yes It was the cable problem, because pinout setting for CSS 11800 different than what CISCO claims: I made a new RJ45 cable with:
-----Comm-server-side -----------------------------------CSS 11800 side ------------
---Color----------Purpose --- PIN #--- PINOUT -----PIN #----Purpose----------Color--
white-orange-----CTS-----------1--      1-1        --1------------------white-orange
------orange-----DSR-----------2--      2-6        --2---------RxD-------------green
-white-green-----RxD-----------3--      3-3        --3---------TxD-------white-green
--------blue-----GND-----------4--      4-7        --4-------------------white-brown
--white-blue-----GND-----------5--      5-5        --5--------------------white-blue
-------green-----TxD-----------6--      6-2        --6------------------------orange
-white-brown-----DTR-----------7--      7-4        --7---------GND--------------blue
-------brown-----RTS-----------8--      8-8        --8-------------------------brown
it works.
