VPN connected but can't access Corporate network
Mar 16th, 2010
My VPN is connected but I cannot seem to access anything on the Corporate network.
It's as if there is no route back through the tunnel.
From the Client VPN log:
The Virtual Adapter was enabled:
IP=192.168.245.2/255.255.255.0
DNS=208.163.60.10,0.0.0.0
WINS=0.0.0.0,0.0.0.0
Domain=
Split DNS Names=
163    20:28:35.991  03/15/10  Sev=Info/4 CM/0x63100038
Successfully saved route changes to file.
164    20:28:36.006  03/15/10  Sev=Info/5 CVPND/0x63400013
    Destination           Netmask           Gateway         Interface   Metric
        0.0.0.0           0.0.0.0       192.168.1.1     192.168.1.198       25
  67.113.19.206   255.255.255.255       192.168.1.1     192.168.1.198      100
      127.0.0.0         255.0.0.0         127.0.0.1         127.0.0.1      306
      127.0.0.1   255.255.255.255         127.0.0.1         127.0.0.1      306
127.255.255.255   255.255.255.255         127.0.0.1         127.0.0.1      306
    192.168.1.0     255.255.255.0     192.168.1.198     192.168.1.198      281
    192.168.1.1   255.255.255.255     192.168.1.198     192.168.1.198      100
  192.168.1.198   255.255.255.255     192.168.1.198     192.168.1.198      281
  192.168.1.255   255.255.255.255     192.168.1.198     192.168.1.198      281
  192.168.201.0     255.255.255.0     192.168.245.1     192.168.245.2      100
  192.168.245.0     255.255.255.0     192.168.245.2     192.168.245.2      276
  192.168.245.2   255.255.255.255     192.168.245.2     192.168.245.2      276
192.168.245.255   255.255.255.255     192.168.245.2     192.168.245.2      276
      224.0.0.0         240.0.0.0         127.0.0.1         127.0.0.1      306
      224.0.0.0         240.0.0.0     192.168.1.198     192.168.1.198      281
      224.0.0.0         240.0.0.0     192.168.245.2     192.168.245.2      276
255.255.255.255   255.255.255.255         127.0.0.1         127.0.0.1      306
255.255.255.255   255.255.255.255     192.168.1.198     192.168.1.198      281
255.255.255.255   255.255.255.255     192.168.245.2     192.168.245.2      276
165    20:28:36.006  03/15/10  Sev=Info/6 CM/0x63100036
The routing table was updated for the Virtual Adapter
166    20:28:36.006  03/15/10  Sev=Info/4 CM/0x6310001A
One secure connection established
I cannot ping any server within the corporate network (192.168.201.0/24).
I'm not sure what to do to troubleshoot or fix.
Any suggestions?
-Darla
slmansfield Tue, 03/16/2010 - 11:56
  • Silver, 250 points or more
Is there a way for you to check to see if there's a route back through the tunnel?
Is the VPN central site device configured for NAT-T?
sadler.darla Tue, 03/16/2010 - 12:37
NAT-T is enabled on the firewall (ASA5500).
I'm not sure how else to see if there is a route back to the corporate network.  As I mentioned, I cannot ping anything inside the corporate network so that to me says there is no route back.  Do you have another idea for testing this?  tracert does  not even give me one hop.
Thanks!
slmansfield Tue, 03/16/2010 - 12:57
Can you ask someone with access to your corporate network to do a traceroute from one of the servers to your VPN IP address?
