CUCM credential policy
Answered Question
Mar 16th, 2010
Hi ,
I've created 50 users in CUCM with extension mobility. I forgot to change pin policy, I don't want users change thier pin at the next login. I've changed pin policy to not force users to change pin at the next login. But still prompt the users to change thier pin. How can I update new pin policy to all users?
very appreciate for any suggestion.
Alex
Correct Answer by Aaron Harrison about 6 years 10 months ago
You need to clear this setting using BAT (it's a property set on each user, click the 'change credentials' or whatever-it-is button next to the PIN on the end user, or on the equivalent page in BAT).
Sounds like you've changed the default credential, which would then apply to new users...
Aaron
Please rate helpful posts...
Overall Rating: 4.5 (2 ratings)
Correct Answer
Aaron Harrison Tue, 03/16/2010 - 12:07
Aaron
