Basic BGP config - ISP not see announcements
Answered Question
Mar 16th, 2010
I am setting up my first BGP connection to our ISP and when we turned it on I receive his feed but he does not the subnets I am trying to announce.
Any of you BGP gurus out there care to tell me what I am doing wrong?  Is it the Null0 route?  Should I just direct the subnets to his next hop??
Any help is appreciated.
Here is my config.
router bgp 11111
no synchronization
no bgp log-neighbor-changes
network 180.7.253.0
network 180.7.254.0
redistribute static
neighbor 4.4.4.4 remote-as 22222
no auto-summary
ip route 0.0.0.0 0.0.0.0 4.4.4.4
ip route 180.7.2.220 255.255.255.255 180.7.254.125
ip route 180.7.253.0 255.255.255.0 Null0
ip route 180.7.254.0 255.255.255.0 Null0
I am trying to announce the 180.8.253.0 and 180.7.254.0 networks.  The route statement for 180.7.2.220 is a route back inside for my internal FTP server to back up configs.
This is what the ISP sees on his side.
ISP-router#show ip bgp nei x.x.x.x rec
BGP table version is 1348900, local router ID is x.x.x.x
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* 180.7.2.220/32 4.4.4.3 0 0 11111 ?
Total number of prefixes 1
Correct Answer by Jon Marshall about 6 years 10 months ago
srroeder wrote:
Sure ,
router#sho ip bgp 180.7.253.0
BGP routing table entry for 180.7.252.0/22, version 44913
Paths: (1 available, best #1, table Default-IP-Routing-Table)
  Not advertised to any peer
  11111
    66.196.17.1 from 66.196.17.1 (66.196.29.33)
      Origin IGP, localpref 100, valid, external, best
hqprt02#sho ip bgp 180.7.254.0
  11111
Okay, your BGP table is showing a route entry for 180.7.252.0 255.255.252 so do you know where you are getting this route from ? What is 66.196.17.1 ?
Sorry to keep asking for outputs but can you do
1) sh ip bgp | include 180.7.
2) sh ip bgp 180.7.253.0 255.255.255.0
3) sh ip route | include 180.7
4) sh ip route 180.7.253.0 255.255.255.0
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 03/16/2010 - 12:26
Can you post from your router -
1) sh ip bgp
2) sh ip bgp neighbor 4.4.4.4 advertised-routes
By the way, you shouldn't need the network statements as your redistribute static should cover those additional static routes.
Jon
srroeder Tue, 03/16/2010 - 13:10
Thanks for the reply,   when I do a "sho ip bgp" I get a list of 40000 some odd routes......   here are the first few lines......
hqprt02#sho ip bgp
BGP table version is 69053, local router ID is 180.7.254.126
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
r> 0.0.0.0          4.4.4.4                            0 10756 i
*> 1.0.0.0          4.4.4.4                            0 10756 1239 3356 365
61 i
*> 2.0.0.0/16       4.4.4.4                            0 10756 1239 6762 126
54 i
*> 3.0.0.0          4.4.4.4                           0 10756 1239 15412 93
hqprt02#sho ip bgp neig 4.4.4.4 advertised-routes
BGP table version is 69031, local router ID is 180.7.254.126
*> 180.7.2.220/32   180.7.254.125            0         32768 ?
Jon Marshall Tue, 03/16/2010 - 13:17
Okay, sorry.
Can you do a "sh ip bgp" for the specific routes you have the null0 static routes for. I just want to make sure they are in the BGP table. Also can you do a "sh ip route" for the same routes to make sure they are in the routing table.
Jon
srroeder Tue, 03/16/2010 - 13:29
Sure ,
  11111
  11111
Correct Answer
Jon Marshall Tue, 03/16/2010 - 13:38
srroeder wrote:
Sure ,
  11111
  11111
Jon
srroeder Tue, 03/16/2010 - 13:59
Jon,
OK ,  I feel like a real dummy,   the 66.196.17.1 is another ISP we have a connection to and he is announcing that CIDR back to me.  I believe that is the cause of my problems.  I will contact them.
Thanks for your help.
Steve
