H.323 GW in remote location drops outbound calls few seconds later while trying to setup call.
Mar 16th, 2010
Hi, I've deployed an H.323 GW which can place and receive calls
from PSTN when using directly registered phones. However, when moving phones to a Communications Manager (v.6.1.4) they cannot place outbound calls to PSTN (but can receive calls without any problem).
Soon after answering the call or if I wait ringing it gets disconnected after about 8 seconds. Debug ISDN Q931 shows:
.Mar 16 19:19:30.624: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0082
        Cause i = 0x80AF - Resource unavailable, unspecified
It feels like there is some H.323 capability error/mismatch between CUCM and the GW. Any idea of any settings in the GW or GW setup in CUCM that might be preventing communication?
router relelavant setup:
isdn switch-type primary-net5
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
supplementary-service h450.12
fax protocol t38 nse force ls-redundancy 5 hs-redundancy 2 fallback pass-through g711ulaw
h323
  call preserve
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class codec 2
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 2
voice translation-profile RAMAIS
translate called 1
voice translation-profile SAIDA
translate calling 2
voice-card 0
dsp services dspfarm
controller E1 0/0/0
pri-group timeslots 1-31
description PSTN
controller E1 0/0/1
shutdown
description PSTN
interface FastEthernet0/0
description ## INTERFACE TO CALLMANAGER ##
ip address 10.20.47.2 255.255.255.0
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.20.47.2
service-policy output set-dscp
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:15
translation-profile incoming RAMAIS
translation-profile outgoing SAIDA
disc_pi_off
cptone BR
description PSTN
bearer-cap Speech
ccm-manager music-on-hold
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
sccp local FastEthernet0/0
sccp ccm 10.22.10.11 identifier 1 version 4.1
sccp ccm 10.22.10.12 identifier 2 version 4.1
sccp
sccp ccm group 100
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 20 register XCO-BRBRAS-QS-1
associate profile 10 register CFB-BRBRAS-QS-1
dspfarm profile 20 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 6
associate application SCCP
dspfarm profile 10 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dial-peer voice 1000 voip
description ## To CUCM ##
preference 1
destination-pattern 401..
progress_ind setup enable 3
no modem passthrough
voice-class codec 1
voice-class h323 1
session target ipv4:XX.XX.XX.XX
incoming called-number .
dtmf-relay h245-alphanumeric
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
no vad
dial-peer voice 2010 pots
description ## PSTN ##
destination-pattern 0[2-9].......
direct-inward-dial
port 0/0/0:15
Thanks a lot.
Related Content
