03-16-2010 01:40 PM
Hi, we just got several laptops that came with Windows 7 Pro 32bit installed, and we have installed the VPN Client 5.0.06.0110. The VPN client appears to connect to our ASA5510, but we are unable to connect to any machines on our network as it does on our XP machines. Furthermore, we cannot ping any as well. Also, while connected the Windows 7 machine is still able to access internet site as if split-tunneling was configured, which its not! I've seen alot of people posting on the internet about the same issue, but I have not run into any resolutions that work. Any ideas?
Jay
03-16-2010 02:51 PM
Jay,
Turn logging on the client on one of the macines and post the output.
03-16-2010 03:12 PM
Here is the log:
Cisco Systems VPN Client Version 5.0.06.0110
Copyright (C) 1998-2009 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.1.7600
6 18:07:10.056 03/16/10 Sev=Warning/2 CVPND/0xE3400013
AddRoute failed to add a route with metric of 0: code 160
Destination 192.168.10.0
Netmask 255.255.255.0
Gateway 10.0.0.1
Interface 10.10.85.54
7 18:07:10.056 03/16/10 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: c0a80a00, Netmask: ffffff00, Interface: a0a5536, Gateway: a000001.
8 18:08:25.839 03/16/10 Sev=Warning/2 CVPND/0xA3400015
Error with call to IpHlpApi.DLL: CheckUpVASettings: Found IPADDR entry addr=10.10.85.54, error 0
9 18:08:26.853 03/16/10 Sev=Warning/2 CVPND/0xA3400015
Error with call to IpHlpApi.DLL: CleanUpVASettings: Was able to delete all VA settings after all, error 0
10 18:08:27.258 03/16/10 Sev=Warning/2 IKE/0xA3000067
Received an IPC message during invalid state (IKE_MAIN:512)
03-17-2010 01:07 AM
I have seen this issue before myself and the causes were:-
1) Running a 32bit client on 64 bit system.
2) Incorrect installation.
3) Firewall issues on software installation.
4) GPO issues on running/installing software.
HTH>
03-17-2010 09:47 AM
It appears to be a routing issue. And for some reason it works fin in XP and not Win 7. Here is some more info:
When doing a Route Print in XP I get:
XP Route Print
C:\>route print
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 18 de 9d 57 0a ...... Intel(R) PRO/Wireless 3945ABG Network Connection
- Teefer2 Miniport
0x3 ...00 15 58 7d 37 1e ...... Intel(R) PRO/1000 PL Network Connection - Teefer
2 Miniport
0xd0005 ...00 05 9a 3c 78 00 ...... Cisco Systems VPN Adapter - Teefer2 Miniport
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 10.10.85.58 10.10.85.58 1
0.0.0.0 0.0.0.0 192.168.10.1 192.168.10.15 20
10.0.0.0 255.0.0.0 10.10.85.58 10.10.85.58 20
10.10.85.58 255.255.255.255 127.0.0.1 127.0.0.1 20
10.255.255.255 255.255.255.255 10.10.85.58 10.10.85.58 20
65.216.134.146 255.255.255.255 192.168.10.1 192.168.10.15 1
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.10.0 255.255.255.0 192.168.10.15 192.168.10.15 20
192.168.10.1 255.255.255.255 192.168.10.15 192.168.10.15 1
192.168.10.15 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.10.255 255.255.255.255 192.168.10.15 192.168.10.15 20
224.0.0.0 240.0.0.0 10.10.85.58 10.10.85.58 20
224.0.0.0 240.0.0.0 192.168.10.15 192.168.10.15 20
255.255.255.255 255.255.255.255 10.10.85.58 10.10.85.58 1
255.255.255.255 255.255.255.255 192.168.10.15 192.168.10.15 1
255.255.255.255 255.255.255.255 192.168.10.15 2 1
Default Gateway: 10.10.85.58
Persistent Routes:
None
When doing a Route Print in Win 7 I get:
C:\>route print
Interface List
21...00 05 9a 3c 78 00 ......Cisco Systems VPN Adapter
11...00 26 9e bc ad bd ......Realtek PCIe GBE Family Controller
1...........................Software Loopback Interface 1
15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
12...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter
14...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
16...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.10.1 192.168.10.33 20
0.0.0.0 0.0.0.0 10.0.0.1 10.10.85.57 100
10.0.0.0 255.0.0.0 On-link 10.10.85.57 276
10.10.85.57 255.255.255.255 On-link 10.10.85.57 276
10.255.255.255 255.255.255.255 On-link 10.10.85.57 276
65.216.134.146 255.255.255.255 192.168.10.1 192.168.10.33 100
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.10.0 255.255.255.0 On-link 192.168.10.33 276
192.168.10.1 255.255.255.255 On-link 192.168.10.33 100
192.168.10.33 255.255.255.255 On-link 192.168.10.33 276
192.168.10.33 255.255.255.255 10.0.0.1 10.10.85.57 276
192.168.10.255 255.255.255.255 On-link 192.168.10.33 276
192.168.10.255 255.255.255.255 10.0.0.1 10.10.85.57 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.10.33 276
224.0.0.0 240.0.0.0 On-link 10.10.85.57 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.10.33 276
255.255.255.255 255.255.255.255 On-link 10.10.85.57 276
Persistent Routes:
None
I was able to make it work by doing the following command, but this is a work around, not a resoltion.
Route –p ADD 192.168.1.0 MASK 255.255.255.0 10.10.85.58 METRIC 1
Jay
03-17-2010 09:52 AM
As I said something is stopping the client from putting the route into the machines local routing table.
04-16-2010 01:41 AM
I get exactly the same problem today on a VPN configuration that used to work recently. The only change I can think of is that there has been a recent security update for Windows 7 on the 14th of April (KB978601, KB979683, KB981332, KB979309, KB80232) which maybe have created the problem? Messages 1 and 2 below appeared when I connected the VPN session. 3 to 6 when I disconnect. It looks like the VPN client is not allowed to add a route. Tried to run VPN client as administrator as well, but it did not help. I include the route prints before and after connecting as well.
(running 32 bit client on 32bit win7, disabled the firewall and the installation has been working before)
Cisco Systems VPN Client Version 5.0.06.0160
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1 09:47:13.903 04/16/10 Sev=Warning/2 CVPND/0xE3400013
Destination 10.10.21.255
Netmask 255.255.255.255
Gateway 10.0.0.1
Interface 10.1.225.161
2 09:47:13.903 04/16/10 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: a0a15ff, Netmask: ffffffff, Interface: a01e1a1, Gateway: a000001.
3 09:54:07.748 04/16/10 Sev=Warning/2 CVPND/0xA3400015
Error with call to IpHlpApi.DLL: CheckUpVASettings: Found IPADDR entry addr=10.1.225.161, error 0
4 09:54:08.751 04/16/10 Sev=Warning/2 CVPND/0xA3400015
5 09:54:09.754 04/16/10 Sev=Warning/2 CVPND/0xA3400015
6 09:54:10.377 04/16/10 Sev=Warning/2 IKE/0xA3000067
Here is a route print before connecting:
H:\>route print
Interface List
11...00 17 31 54 19 34 ......Intel(R) PRO/1000 PL Network Connection
12...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 10.10.21.254 10.10.21.75 20
10.10.21.0 255.255.255.0 On-link 10.10.21.75 276
10.10.21.75 255.255.255.255 On-link 10.10.21.75 276
10.10.21.255 255.255.255.255 On-link 10.10.21.75 276
224.0.0.0 240.0.0.0 On-link 10.10.21.75 276
255.255.255.255 255.255.255.255 On-link 10.10.21.75 276
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 306 ::1/128 On-link
11 276 fe80::/64 On-link
11 276 fe80::11c9:eafd:5583:f83a/128
On-link
1 306 ff00::/8 On-link
11 276 ff00::/8 On-link
Persistent Routes:
None
Here is a route print after connecting
C:\>route print
Interface List
16...00 05 9a 3c 78 00 ......Cisco Systems VPN Adapter
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 10.0.0.1 10.1.225.175 21
10.0.0.0 255.0.0.0 On-link 10.1.225.175 276
10.1.225.175 255.255.255.255 On-link 10.1.225.175 276
10.10.21.0 255.255.255.0 10.0.0.1 10.1.225.175 276
10.10.21.75 255.255.255.255 10.0.0.1 10.1.225.175 276
10.10.21.201 255.255.255.255 On-link 10.10.21.75 100
10.255.255.255 255.255.255.255 On-link 10.1.225.175 276
194.20.70.220 255.255.255.255 10.10.21.254 10.10.21.75 100
224.0.0.0 240.0.0.0 On-link 10.1.225.175 276
255.255.255.255 255.255.255.255 On-link 10.1.225.175 276
Persistent Routes:
Network Address Netmask Gateway Address Metric
IPv6 Route Table
Active Routes:
16 276 fe80::/64 On-link
On-link
16 276 fe80::d48f:c783:79a4:ed52/128
On-link
16 276 ff00::/8 On-link
Persistent Routes:
None
08-17-2010 11:20 AM
I have exactly the same problem. Is there a solution ?
Best regards
BD
09-19-2010 10:38 AM
I am also having this problem.
Plus, I have an addtional question. Is the log message "AddRoute ... with a metric of 0" wrong, or is the VPN client really trying to use a metric of 0?
I do not think 0 is a legal value for a metric.
Ed Lyons
09-21-2010 06:08 AM
Same problem here. Is there a solution ?
Windows 7 Pro, 32bit - Cisco System VPN Client Version 5.0.07.0290
DP
09-21-2010 06:24 AM
I had to open a Cisco TAC Case to get it resolved. I wish I had more info for you guys, but the tech moved quite fast and I did not save the log by accident.
09-22-2010 05:54 AM
I found a solution thats works for me:
1.Uninstall the previous version of Cisco VPN client
2.Reboot
3.Download the Citrix DNE Update and install it (or REPAIR if already installed from a previous attempt) from http://www.citrix.com/lang/English/lp/lp_1680845.asp
or use this link:
Citrix DNE - ftp://files.citrix.com/winfix.exe
32bit update - ftp://files.citrix.com/dneupdate.msi
ftp://files.citrix.com/dneupdate.msi64bit update - ftp://files.citrix.com/dneupdate64.msi
4.Reboot
5.Install the Cisco VPN Client (i use 5.0.07.0290)
7.Reboot
8.Rebuild the connection profile (previous one was no longer visible for some reason)
DP
04-24-2013 10:53 PM
I solved the issue following David Petrik's instructions.
Thanks David.
My scenario was as follows:
Windows 7 professional 32 bits.
Cisco vpn client version 5.0.6 was installed.
Laptop connects to Cisco router 881 but cannot access LAN resources, no Remote Desktop, no ping to default gateway router interface.
Cisco VPN client worked on the laptop for a couple of months and suddenly it stopped working. The reason was not determined.
Other laptops with Windows Xp or Mac OS X worked ok.
FP
05-11-2012 05:15 AM
change client vpn to version 5.0.04.0300 resolved problem
02-17-2013 02:26 PM
I Faced Such issue. WIFI Internet Router in my Home was giving my IP of 192.168.1.x subnet and after connecting to vpn client i want to access ip 192.168.1.x. So it was causing problem because i am locally connted to 1.x and after connecting to vpn client i want to access remote 1.x that was not possible. So i change my WIFI Internet Router Local Subnet to 2.x and problem was solved.
