Tunnel issue
Mar 16th, 2010
I have setup the tunnel in my test lab and am able to reach peer IP firewall..iskmp is up but ipsec is not working..means i am unable to reach inside network of otherside..
config attached..any suggestions/feedback
Sateesh
sateeshk10 Tue, 03/16/2010 - 14:51
I have modifed it...but still same problem.
Sateesh
sateeshk10 Tue, 03/16/2010 - 15:19
Required output has attached..
A - 506E pix(6.2(2)  ---- do i need to upgrade to next or any suggetions on that..
B- 5510 ASA
sateesh
The tunnel has formed OK - traffic is being encrypted by Firewall B, and unencrypted by Firewall A.  However the issue is Firewall A is not encrypted any traffic, this could be of 2 reasons:-
1) The crypto tunnel has formed incorrectly, even though everything looks OK - reboot the firewall
2) There is a routing issue - check that the end device on network firewall A is receving the traffic and
    can respond/route correctly.
HTH>
