SMS Texting on 7921 / 7925
Mar 16th, 2010
Does anyone have a 3rd party recommendation for enabling texting on 7921s and 7925s?
TIA,
Amir
Overall Rating: 5 (1 ratings)
David Hailey Thu, 03/18/2010 - 21:53
It's funny that you ask this because some of the cheaper SPA wireless phones natively support SMS via SIP but not the 7921/7925.  With that said, they are very much geared towards medical use and there are vendors that enable SMS on these phones.  I suggest you check out Radianta - you may need to actually contact a sales rep to see what product suite would be fitting for you, if any.  You may also be able to come up with something via CUAE or a combination of CUAE and a third-party plug-in (Radianta has some of those as well - the Beacon suite).  HTH.
Hailey
Please rate helpful posts!
