03-16-2010 03:36 PM
Hi all,
I'm probably being thick here, but I cannot set an ntp server reference on my Cisco 857:
cisco#sh ver
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
cisco#ntp ?% Unrecognized command
cisco#conf tEnter configuration commands, one per line. End with CNTL/Z.
cisco(config)#ntp ?
What am I missing (apart from several hours sleep)?
Rich.
Solved! Go to Solution.
03-16-2010 03:38 PM
850 doesn't support NTP. Try using "sntp server
If my post is helpful, may I request if you can rate it? Thank you very much.
03-16-2010 03:38 PM
