CUCM and Avaya
Mar 16th, 2010
I am integrating a CUCM 7.02 with a S8400 Avay PBX through h.323.
I added a h.323 gateway in CUCM with Avaya IP address and tested the integration.
But I only receive calls from Avaya PBX. I am not able to make calls from CUCM to Avaya.
The codec is setup to G711ulaw. I´ve tried  Fast Start with Media  Termination Point, but it didn´t work.
Does someone already experienced this kind of problem?
Aaron Harrison Wed, 03/17/2010 - 01:40
Have you added a route pattern to point send calls to the H.323 gateway?
Aaron
cfujimura Fri, 03/19/2010 - 09:59
Aaron, thanks for the reply.
Related to the route patterns, they are pointing to the gateway.
I solved the problem with CUBE. I´ve used a sip trunk to the cube and a H.323 call leg to avaya (I´ve configured that on CUBE).
After that, calls are working normally.
Carlos Fujimura.
