SWF not working in DMP-4305G ??
Mar 16th, 2010
Hi all
I have created a simple SWF file, which just display a Helloworld text only
Save it as .swf with Flash player version 7
I have uploaded the swf to a web server. i.e.
In the Cisco Digital Media Play Device manager > URL to be displayed
the URL is:
after I press the "Go" button, the DMP respond the following error message.
/tmp/ftproot/usb_1/.tmp/kxext14n.swf could not be saved because the source file could not be read
Am I missing any config?
Thanks and regards,
jason-galloway Fri, 03/19/2010 - 11:45
Did you get any answers on this?
If you uploaded the file to the server it shoule be visible in the DMM so in the Presentation editor you can add a video playlist, then add it via the content manager...Right?
samhopealpha Mon, 03/22/2010 - 19:23
The problem is solved by inserting the SWF object in .htm file
I guess the player can't play the .SWF file directly ...
jason-galloway Tue, 03/23/2010 - 08:49
Alirght, thanks for the reply! I guess that would make sense that it needed something to facilitate the swf file.
Related Content
