AIM-CUE upgrade from ver 2.2 to ver 8.0
Mar 17th, 2010
How can we upgrade from ver 2.2 to 8.0, is this possible ?
I have AA scripts running on that aim-cue but I cant make new scripts because I cant find v2.2 script editor. I couldnt find a place to download and see that it is end of support. So I think I need to upgrade to newer versions but when I upgrade can my AA script work without changing anything on the script? Or do I need to write it again? Is the configuration on the cue will be deleted or not ? What about the licenses do I need a license for upgrade ?
Aaron Harrison Wed, 03/17/2010 - 01:47
  • Community Spotlight Award,
    Member's Choice, May 2015
Easy option - use the search option at www.cisco.com/go/software to search for cueeditor - this will throw up all the versions that are available even if you can't browse to them using the usual menus. A shortcut:
http://www.cisco.com/pcgi-bin/swsrch/SWSearch_results.cgi/SWSearch.txt?s...
Aaron
Please rate helpful posts...
