Cisco Security Agent - CSA Logging features
Answered Question
Mar 17th, 2010
Please, I need yours help.
I have some questions which must be answered ASAP.
Is it possible
Logging - File copy from local drive to removable storages
Logging - File copy from network drive to removable disk
Logging – System parameters change
Logging – Connection to share on computer???
Correct Answer by dkthomas about 7 years 4 months ago
Actually you can monitor... if an event is logged into the Windows event logger, CSA can log that event as well....
We used the event logger to pull specific event log information into out CSA logs.. like, login and logout and disk errors.
I hope that helps,
-dt
Correct Answer by jan.nielsen about 7 years 4 months ago
   -registry changes
Yes
  - changing or replacing important system  files
Yes
  or any system changes which maybe take to instability  operating system normal functionality..
Much harder, since this is a million different ways an o/s could become unstable, but looking at certain system registry keys and system/system32 directories will give you alot of information you are looking for.
Sorry it was incorrect.
Logging – Connection  to share folder on agent's computer?
Yes, you can log read/write access to a local folder which is shared, and with source @network in your rules, the actual attempt to connect to the share is probably a bit more difficult.
Overall Rating: 4.7 (3 ratings)
jan.nielsen Wed, 03/17/2010 - 05:59
  • Gold, 750 points or more
Yes
Yes
Don't know what you are referring to...registry changes ?
What do you mean, just the actual attempt to connect to the machine, or the accessing of data on the share ?
secureboy Wed, 03/17/2010 - 06:14
Thank you for quick reply..
I am referring that
  -registry changes
Correct Answer
jan.nielsen Wed, 03/17/2010 - 09:19
   -registry changes
Yes
Yes
Correct Answer
dkthomas Thu, 03/18/2010 - 18:17
I hope that helps,
-dt
Related Content
