03-17-2010 01:43 AM - edited 03-04-2019 07:50 AM
Sir,
I have done multilink between cisco and nortel router.Its working fine.Some times multilink is up but not passing packets.If i give shutdown and no shutdown to multilink found packets are passing.
1.Any additional commands are there to multilink cisco and nortel router.What may be the problem.
Senthil
03-17-2010 05:50 AM
Hello Senthil,
this adds information to your previous thread.
PPP multilink is a standard so it should work and no special commands should be given to improve the behaviour
what is the PPP state in sh ppp multilink when user traffic doe not pass over it ?
the shut/ no shut resets the PPP state machine.
Hope to help
Giuseppe
03-19-2010 09:45 PM
Dear sir,
Output of Show ppp multilink while multilink up but not pinging is\
Multilink2, bundle name is ROUTER
Bundle up for 20:58:58
Bundle is Distributed
0 lost fragments, 1686 reordered, 0 unassigned
0 discarded, 0 lost received, 1/255 load
0xBB2A4 received sequence, 0x64C109 sent sequence
Member links: 16 active, 0 inactive (max not set, min not set)
Se1/1/0/1:0, since 11:08:36, no frags rcvd
Se1/1/0/2:0, since 11:08:36, no frags rcvd
Se1/1/0/3:0, since 11:08:36, no frags rcvd
Se1/1/0/4:0, since 11:08:36, no frags rcvd
Se1/1/0/5:0, since 11:08:36, no frags rcvd
Se1/1/0/6:0, since 11:08:36, no frags rcvd
Se1/1/0/7:0, since 11:08:36, no frags rcvd
Se1/1/0/8:0, since 11:08:36, no frags rcvd
Se1/1/0/9:0, since 11:08:36, no frags rcvd
Se1/1/0/10:0, since 11:08:36, no frags rcvd
Se1/1/0/11:0, since 11:08:36, no frags rcvd
Se1/1/0/12:0, since 11:08:36, no frags rcvd
Se1/1/0/13:0, since 11:08:36, no frags rcvd
Se1/1/0/14:0, since 11:08:36, no frags rcvd
Se1/1/0/15:0, since 11:08:36, no frags rcvd
Se1/1/0/16:0, since 11:08:36, no frags rcvd
Thanks and Regards,
senthil
03-19-2010 10:11 PM
Sir,SH ppp multilink output of another multilink
Multilink1, bundle name is RTR
Bundle up for 4d12h
22 lost fragments, 1183131 reordered, 0 unassigned
5 discarded, 7 lost received, 1/255 load
0x4ACD received sequence, 0x282B09 sent sequence
Member links: 2 active, 0 inactive (max not set, min not set)
Serial5/1:0, since 00:15:47, last rcvd seq 004ACC
Serial3/3:0, since 05:43:23, last rcvd seq 004ACB.
Thanks and Regards,
Senthil
03-19-2010 09:54 PM
Kumar, make sure UDP traffic is enable on Nortel router. Some of the nortel routers don't handle UDP multilink traffic well. Look into pim or igmp forwarding solutions for your Nortel router.
Thx,
Eric
03-19-2010 10:13 PM
Sir,i am not expert in nortel router.how to check udp is enabled .
Thanks and Regards,
Senthil
03-20-2010 04:54 AM
please provide your Nortel Router model and current version.
Thx,
Eric
03-20-2010 05:10 AM
Sir,
Nortel secure 3120 router.
OPAL SW VERSION: r9.2
Thanks and Regards,
Senthil
