VPN tunnel from Cisco Client to ASA 5505 up but internal network not reachable
Mar 17th, 2010
I need advice from the experts. I have a site-to-site VPN tunnel running between two of our branches and also need remote access for our users with cisco vpn clients. The site-to-site VPN works like a charm, I was even able to get the remote access tunnel up but I'm not able to reach any IP in the internal LAN 10.0.0.0 but split tunnel traffic is separated correctly. I have attached a little image of the network design plus the running config of both ASA devices. Any help on this is much appreciated. Thanks,
There is a static route on router .1 to the ASA (A) to .4
route inside 10.137.8.0 255.255.252.0 10.137.4.4
I have also ripped away parts of the config which are not relevant to the VPN config
CISCO ASA (A) CONFIG
ASA Version 7.2(3)
hostname EAZRHFW01
interface Vlan1
nameif inside
security-level 100
ip address 10.137.4.4 255.255.252.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.53.98 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
same-security-traffic permit intra-interface
access-list outside_access_in extended permit icmp any any
access-list outside_1_cryptomap extended permit ip 10.0.0.0 255.0.0.0 10.0.0.0 255.0.0.0
access-list inside_nat0_outbound extended permit ip 10.0.0.0 255.0.0.0 10.0.0.0 255.0.0.0
access-list Split_Tunnel_List standard permit 10.0.0.0 255.0.0.0
access-list outside_cryptoap_dyn_20 extended permit ip any 10.0.0.0 255.0.0.0
ip local pool 10.137.9/24 10.137.9.50-10.137.9.150 mask 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 xxx.xxx.53.97 255
route inside 10.32.0.0 255.255.0.0 10.137.4.1 1
route inside 10.128.0.0 255.255.0.0 10.137.4.1 1
route inside 10.137.12.0 255.255.252.0 10.137.4.1 1
route inside 10.137.16.0 255.255.252.0 10.137.4.1 1
route inside 10.137.20.0 255.255.252.0 10.137.4.1 1
route inside 10.193.0.0 255.255.0.0 10.137.4.1 1
aaa-server EAZRHDC1 protocol nt
aaa-server EAZRHDC1 host 10.137.4.10
nt-auth-domain-controller eazrhdc1
aaa-server EAZRHAUT protocol radius
aaa-server EAZRHAUT host 10.137.6.24
key hard2get4u
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 10 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 10 set security-association lifetime seconds 288000
crypto dynamic-map outside_dyn_map 10 set reverse-route
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer xxx.xxx.53.99 157.161.230.155
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 10 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal  20
class-map inspection_default
match default-inspection-traffic
service-policy global_policy global
group-policy ZurichRAS internal
group-policy ZurichRAS attributes
dns-server value 10.137.4.10
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Split_Tunnel_List
default-domain value eazrh.ch
username atonina password IfQDIRGV5C0dXHUa encrypted
tunnel-group 157.161.230.155 type ipsec-l2l
tunnel-group 157.161.230.155 ipsec-attributes
pre-shared-key *
tunnel-group ZurichRAS type ipsec-ra
tunnel-group ZurichRAS general-attributes
address-pool 10.137.9/24
authentication-server-group EAZRHAUT
default-group-policy ZurichRAS
tunnel-group ZurichRAS ipsec-attributes
pre-shared-key *
CISCO ASA (B) CONFIG
ASA Version 7.2(4)
hostname EABSLFW01
interface Vlan1
nameif inside
security-level 100
ip address 10.137.8.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.230.155 255.255.255.248
route outside 0.0.0.0 0.0.0.0 xxx.xxx.230.153 255
crypto map outside_map 1 set peer xxx.xxx.53.98
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group xxx.xxx.53.98 type ipsec-l2l
tunnel-group xxx.xxx.53.98 ipsec-attributes
pre-shared-key *
vladimirtegeltija Wed, 03/17/2010 - 03:41
I'm no an expert but I think I might found something!
When you connect with vpn remote access (cisco VPN client software) you
got the ip address from local pool :
than you for example try to ping remote subnetworks (in cloud 10.0.0./8),
when Asa decrypts packets from you it see that you have address from
local pool (source address), and that is in 10.0.0.0/8 network range, and because
you try to ping 10.0.0.0/8 network cloud (destination address), in my opinion that traffic
will go via site-to-site tunnell because in your interesting traffic you said :
I think the solution will be to change your address pool for vpn clients to something
that is not in 10.0.0.0/8 network range, of course you have to adjust nat exemption
to new pool and that stuff...
I hope it helps,
sorry, I'm not an expert!
deyassccna Wed, 03/17/2010 - 05:49
Hello, experts!
unfortunately I'm not, too
ASA ver7.x dose not support an asymmetric routing. ( There's another gateway inside, right? )
It was supported in version 8.2(1) or later.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_qanda_item09186a00805b87d8.shtml#asym
http://inetpro.org/wiki/ASA_Asymmetric_Routing
I hope this could be some help to you, but please forgive me if my post is missing the point..
deyass
vladimirtegeltija Wed, 03/17/2010 - 07:02
Hello deyassccna,
yeah, you right, it could be asymmetric routing isue if it is the case!
But I can not see that from the image or configurations!
Thanks for your suggestion.
brinks.switzerland Wed, 03/17/2010 - 07:43
You are right with the second gateway. Frankly, I had to google the meaning of asymetric routing first when I read your post but I think asymetric routing is not really the issue. I cannot reach any IP of our subnets over remote access.
brinks.switzerland Wed, 03/17/2010 - 07:35
Thanks for your reply. I think the problem is somewhere with routing and ACL. Problem is, remote access alone without site-to-site VPN is working, but together it is not. I will try to define separate cryptomaps for the site-to-site and remote access VPN.
vladimirtegeltija Wed, 03/17/2010 - 08:00
Hello again,
considering your reply where you say that remote  access is working
when there is not site-to-site I'm even more  convinced that your traffic
is going through site-to-site tunnel,  look at my first reply!
You have already two diferent  cryptomaps :
outside_map 1 and  outside_map 10 are 2 diferent crypto maps! You just have to adjust  interesting traffic
for site-to-site tunnel and remote access. Try  to change address pool for remote access, like I said before!
Good  Luck!
brinks.switzerland Wed, 03/17/2010 - 08:50
You were right regarding interessting traffic. After I changed the IP pool to something outside 10.0.0.0/8 the remote access works. Thanks a lot
vladimirtegeltija Wed, 03/17/2010 - 23:46
Hello again,
I'm glad that my help was usefull,
see you again on support community :-)!
Vladimir
deyassccna Thu, 03/18/2010 - 17:30
Hello, Vladimir !
That was great news and wonderful assistance of you.
I'm looking forward to seeing you two again somewhere in this forum...
