Loosing BLF while moving IP phones inside the same VLAN
Mar 17th, 2010
I was moving 40 phones inside the same VLAN. But 3 of them loose some BLF after the reboots.
I reset them. The user on it login and logout. But they doesn't reappeared.
Is there a known bug ?
I was using 7962 with 7915 extension with SCCP42.8-3-5S and extension mobility.
Call Manager version 6.1.2.1110-3
Best regards
Charles
cperroquin Wed, 03/17/2010 - 02:20
I had to do a dummy edit on the BLF page.
But I would like to avoid this kind of problem in the future.
Charles
Related Content
