WCCP Service
Mar 17th, 2010
I have Cat 4506 with  Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9K91S-M), Version  12.2(25)EWA.
This Version is not support for WCCP Service.Could you Please Suggest me which IOS Software version will support WCCP feature.
Jon Marshall Wed, 03/17/2010 - 04:20
Balaji
Feature Navigator is the tool to use for this sort of request -
Feature Navigator
Select "Search by Feature" and then choose WCCP and then you get the option to enter your platform details ie. 4500 with sup V for example. It will then show you a list of IOS versions for that platform that support WCCP.
Jon
Giuseppe Larosa Wed, 03/17/2010 - 06:08
Hello Balaji,
as noted by Jon there are hardware requirements also for this platform to support netflow use feature navigator as suggested to find out a supporting HW configuration it may not be only a question of IOS image.
Hope to help
Giuseppe
Related Content
