CWLMS 3.2 - Topolgy views
paulhowlett_2
Hi, is it possible to display port information on the Topology View maps? I'm exporting the maps into Visio. The hostname shows up but not port connectivity.
Thank you in advance.
Joe Clarke
When exporting, make sure you select all devices as well as all links.  When you do, the links will be exported, but the details of those links will not be.  that is, you should see interconnections between devices, but the details as to which port connects to which port will not be there.  There is no way to export those details to Visio.
Joe Clarke
Hi thanks. It's a shame about the details, it was exactly that I was after.
