Cisco ACE 4710-k9-V3 and OCS
Answered Question
Mar 17th, 2010
I need to know if Cisco ACE 4710-k9-V3 has been tested with OCS Load Balancing, I see this chart here:
http://technet.microsoft.com/en-us/office/ocs/cc843611.aspx
That says that software version 2.1 is the tested one, but I am not familiar with Cisco naming nomenclature, for example I do not know if the "V3" means the software version (as in the chart 2.1).
So if you guys can help me with this I will appreciate.
Correct Answer by Giuseppe Larosa about 6 years 10 months ago
hello Andres,
I would say you have a newer image.
to be noted the microsoft link has a link to a cisco document for deploying load balancing for MS OCS
http://www.cisco.com/en/US/docs/solutions/Verticals/ansmsocs.html
in that document the SW running on ACE was:
>>system: Version A2(1.0) (latest version of ACE  code)
>> system: Version A3(2.0) [build  3.0(0)A3(2.0)
and you should be able to use it for your purposes.
The document provides some options and you should make a choice and then follow the path you have chosen.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Reza Sharifi Wed, 03/17/2010 - 07:13
Hi Andres,
The latest versions on CCO are A2(2.3), A2(1.6a) and A2(3.0). With A2(2.3) is the very latest.
Reza
andresg1980 Wed, 03/17/2010 - 07:34
Reza
First of all, many thanks for your answer.
Sorry, but I am not familiar with cisco so I do not fully understood what you said. What means CCO? What ACE Version might have the 4710-k9-v3 device?
thanks
Giuseppe Larosa Wed, 03/17/2010 - 09:11
Hello Andres,
CCO stands for Cisco connection on line and simply indicates the Cisco website.
ACE can be a standalone appliance or a module that can be inserted in a C6500 lan switch.
In your case is the standalone appliance
In any case the ACE has its own operating system and the versions that Reza has reported refer to this.
see this page about this appliance
http://www.cisco.com/en/US/products/ps7027/products_installation_and_configuration_guides_list.html
Hope to help
Giuseppe
Correct Answer
Giuseppe Larosa Tue, 03/23/2010 - 05:54
hello Andres,
Hope to help
Giuseppe
