4506 add routing and vlan?
Mar 17th, 2010
Also Posted at WAN switching & routing by mistake.
We have two 4506's only doing layer2 and one Vlan
Another vlan is requested.
We don't want to mess with the WAN router.
Is it just a config to add routing and Vlan, or is an upgrade necessary?
Below is a look at the system.
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(20)EW
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 29-Jul-05 18:09 by kellythw
Image text-base: 0x00000000, data-base: 0x011F8610
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 34
System returned to ROM by reload
System restarted at 13:29:10 CST Sat Mar 3 2007
System image file is "bootflash:"
cisco WS-C4506 (MPC8245) processor (revision 10) with 262144K bytes of memory
Processor board ID FOX092603Q7
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from Reload
1 Virtual Ethernet/IEEE 802.3  interface(s)
192 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
colinkiely1 Wed, 03/17/2010 - 07:35
Sure you can do both without any config on the router
Create the SVI on the L3 switch, add the vlan and dont forget to enable routing!
Leo Laohoo Wed, 03/17/2010 - 15:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Errr ... I don't think Yuk Ster can enable routing.  The Sup2+ is a layer 2 only card.
Dot1Q and sub-interface has to be created on the router.
