two or more chassis with clustered fabric interconnect
Answered Question
Mar 17th, 2010
Hi experts
Just wanna confirm the proper way to connect two or more UCS 5108 chassis with a pair of clustered 6120xp fabric interconnect.
I though they should connect like this: the first fabric extender of all chassis should connect to fabric interconnect A, and second fabric extender of all chassis connects to fabric interconnect B. like in the diagram here:  https://supportforums.cisco.com/docs/DOC-5949
however I have seen someone did this: chassis 1 connects as I though above, but for chassis 2, fabric extender 1 connecting to fabric interconnect B, and fabric extender 2 connecting fabric interconnect A - crossed over.
can someone tell me which is appropiate/best practice? any reason why crossing over on the second chassis??
thanks
ming
Correct Answer by Anonymous about 6 years 11 months ago
ming, you need to fix that implementation.  it's like ghostbusters: don't cross the streams!
Always consistently cable chassis fex to the same fabric interconnect.  Most common setup:
Fabric Interconnect A (Primary) is connected to all Left Hand (looking from back of chassis) FEX
Fabric Interconnect B (Subordinate) is connected to all Right Hand FEX.
Why?  You will get errors (can't be bothered looking them up!) and if you move a Service Profile from one chassis to another chassis that is cabled differently, then it won't work (CNAs cabled to different FIs where VIFs are active / inactive = bad).
PS - to change this, if I was you, I would power down the whole system - fabric interconnects, chassis, everything.  then re-cable.  then power up the fabric interconnects and chassis and check the configurations are ok.
Overall Rating: 5 (1 ratings)
Correct Answer
stechamb Wed, 03/17/2010 - 08:22
minghui.qi Thu, 03/18/2010 - 06:31
Hi Steve,
thanks for your reply, I will get it fixed:
could you plealse explain a bit more on "it won't work (CNAs cabled to different FIs where VIFs are active / inactive = bad).", just wanna be clear on the real impact.. or please point me to a link or doc, I can't find such confiugration on standard Cisco Nexus 1000 v docs.
thank you
ming
minghui.qi Wed, 03/24/2010 - 07:32
Thanks, Nethaji.. I have already got that doc. but I can't find it mentioning about two more more chassis connectivity, maybe I missed it?
