WAAS : CIFS Licence Expired
Mar 17th, 2010
Currently experiencing a performance issue at one of our remote offices. Logged into the NME-WAE-502-K9 and issued the show acc command.
TIAWAE-01#show acc
Accelerator  Licensed      Config State    Operational State
cifs              Yes              Enabled        Expired License
epm             Yes              Enabled         Running
http              Yes              Enabled         Running
mapi             Yes              Enabled         Running
nfs               Yes               Enabled         Running
ssl               Yes               Enabled         Running
video             No                Enabled         Shutdown
wafs-core        Yes             Disabled        Shutdown
wafs-edge       Yes             Disabled        Shutdown
Ties in with what the users are seeing - i.e. slow file share access. So whats the next steps?
AJAZ NAWAZ Wed, 04/14/2010 - 07:15
Swinters -
This was a bug - check out /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} CSCta42359
The suggested workaround resolved it.
Software Release 4.1.3
