Cannot load MIB on HUM
Mar 17th, 2010
Hi all,
I am trying to load CISCO-VOICE-DIAL-CONTROL-MIB to HUM. Bu I cannot load two of the dependencies: DIAL-CONTROL-MIB and INT-SERV-MIB.
Although all the dependencies of these two mibs are laoded, when I try to load these two mibs, I get the error "Unable to load the MIB file. Either you are trying to load an invalid MIB file  or the dependent MIB files are not available in the path."
What can be the cause of this problem?
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 03/19/2010 - 11:09
Don't try loading all of the dependencies.  Just make sure they are all in the mibs directory.  Then, replace your file with this one.  Then just try loading the directly.
Related Content
