Configure site-to-site VPN with CCP
Answered Question
Mar 17th, 2010
I have several site-to-site VPNs from small offices, to the main office.
Is possible to do a single configuration for all the VPNs on the "vpn server"(ISR 1801) or I always need to add a entry for each VPN subnet? If so, is possible with CCP?
Nuno
Correct Answer by Federico Coto F... about 7 years 3 months ago
You can configure then VPNs using CCP.
I prefer the command line, and if there are many Site-to-Site VPNs, you can have a template, and all that changes from one VPN to another is the interesting traffic, the peer IP and the pre-shared key.
This depends on the policies.
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Wed, 03/17/2010 - 10:18
  • Green, 3000 points or more
Federico.
nunojpg00 Wed, 03/17/2010 - 11:16
Thanks for your answer. I guess that templates are out of bound for CCP...
You prefer the command line? I would say you configure cisco routers more than once a year
CCP is a terrible software but makes cisco routers usable to someone that only wants to configure a router once in is life.
