03-17-2010 09:18 AM - edited 03-15-2019 09:49 PM
I am running CallManager 4.1(3)sr4b and am having an issue with certain phones updating with the DST. Mainly my 7940s. I have applied new firmware and reset the devices to no avail. Every other phone I have seems to have updated the time just fine (7960, 7961, 7970, etc...).
I will be upgrading to CUCM 7.3 in about 2 months, but that is too long to wait for the fix. Do I need to upgrade to CM 4.1(3)sr8a for the fix, or is the some type of workaround for the issue, hopefully without putting the affected phones ina seperate TZ or anything.
Solved! Go to Solution.
03-17-2010 09:59 AM
The DST note says you need to be past sr4d:
Products Affected | Comments |
Cisco Phones - All Cisco Phones | For 7906, 7911, 7941, 7961, 7970, 7971, please note additional workaround |
Cisco Unified CallManager - 3.3(x) | Includes SR's 3.3(5)SR2 and below |
Cisco Unified CallManager - 4.0(X) | |
Cisco Unified CallManager - 4.1(x) | Includes SR's 4.1(3)SR4d and below |
Cisco Unified CallManager - 4.2(x) | Includes SR's 4.2(3)SR1 and below |
Cisco Unified Communications Manager - 4.3(x) | |
Cisco Unified Communications Manager - 5.0(4) | |
Cisco Unified Communications Manager - 5.1(x) | |
Cisco Unified Communications Manager - 6.0(x) |
http://www.cisco.com/en/US/customer/ts/fn/620/fn62669.html
I also saw some old discussion of modifying the SQL table to adjust the dates, possibly workaround if you don't want to load the SR:
Hi Phillip,
This problem for 7940's and 7960's was discovered yesterday AM. Here is a good description of the fix from Mahesh@Cisco (I guess this was part of the OS Upgrade not mentioned in the Manual Workaround);
If the issue is only with 7940/60 phones, then we have seen a lot of similar cases today and are working to get a permanent fix to the issue. However as a workaround, you could resolve it by going into the Start >> Programs >> Microsoft SQL Server >> Enterprise Manager >> CCM database >> Table >> "TypeTimeZone" >> Right Click Open Table >> Return All Rows and manually set the "stddate" and "dstdate" to "0/11/0/1,2:0:0:0" and "0/3/0/2,2:0:0:0" respectively for each US timezone.
CM Service needs to be restarted.
From this long detailed thread;
Or, you could just wait a few weeks for them to catch up when they switch on the old schedule..
Mary Beth
03-17-2010 09:59 AM
Hi Phillip,
Mary Beth
03-17-2010 01:26 PM
Thanks for the speedy reponses and the fix. I am going out for bid on my new equipment, so don't want to hassle with an update at this time. I went ahead and applied the SQL fix. I will be performing a reboot tongiht due to installing the Data Migration Tool, which will also take care of the service.
I appreciate all the help, and will let you know how things go in the morning.
03-18-2010 05:55 AM
How did it go with the SQL fix. I have the same issue and do not want to push this ahead
if it does not work.
03-18-2010 06:19 AM
I just go through making my rounds and checking the 7940s/7960s that were having the time issue. They all seem to be reporting the correct time, so the SQL did the job nicley.
03-24-2010 07:08 AM
It seems I still have a couple 7940s who are displaying the incorrect time. I have tried resetting them and restarting them, but they refuse to update the time. It is more of a curiosity issue at this point, since they should be catching up to the time in a weeks or so anyway.
03-24-2010 09:54 AM
hmm - that is odd, it might not be worth the trouble to try factory defaulting one - since they are supposed to be getting their time from the CM, and they are not updating, maybe something is stuck..
Mary Beth
03-17-2010 10:02 AM
Luckily, the last service update for CCM is still available for download. The release notes are basically non-existent but the release date is 03/Nov/2008. Looks like the SQL fix may worth a shot vs. the CM update.
Hailey
Please rate helpful posts!
03-17-2010 01:27 PM
I did get the latest update for CM 4.1(3) but only wanted to use it in a last resort kind of thing.
Thanks for the suggestion.
