Simple mGRE
martinbuffleo
I hoping some one can help me, I need to write a configure so that I can set up a tunnel between a static address router and a dynamic address router.
I know I need to use mGRE and NHRP but I can seem to get it working.
Don't suppose any one has a base level config for the static and the dynamic router just so I can atleast get the tunnel inplace.
All the Cisco guide keep over complicating things with IPSEC which I don't need or want.
Thanks in advance.
Liam Devine
Try this:
On your Hub router:
int tunnel 0
     ip address 10.0.0.1 255.255.255.0 ! Change this as required
     tunnel source fa 0/0 ! or whatver interface you wish to use
     tunnel mode gre multipoint
     tunnel path-mtu-discovery
     ip nhrp auth Cisco123 ! change Cisco123 to whatever you like so long as you change it on all spokes as well
     ip nhrp network-id 1010 ! again 1010 can be changed as desired as long as the change is mirrored on the spokes
     ip nhrp map multicast dynamic
     no shut
     exit
router eigrp 1
     no auto-summary
     passive-interface default
     no passive-interface tunnel 0
     network 10.0.0.1 ! tunnel ip
     network 172.16.1.1 ! internal LAN
exit
On your Spoke router(s):
int tunnel 0
     ip address 10.0.0.2 255.255.255.0
     tunnel source fa 0/0 !again variable
     ip nhrp nhs 10.0.0.1 !this points to the hub end of the tunnel
     ip nhrp auth Cisco123 !must match Hub auth string
     ip nhrp map 10.0.0.1 200.0.0.1 ! 200.0.0.1 = ip address of source interface on hub router, change accordingly
     no shut
router eigrp 1
     no auto-summary
     network 10.0.0.2 ! tunnel ip
     network 172.16.2.1 ! internal LAN ip
exit
Now have a cup of tea, a biscuit and a nice sit down.
