switchport mode access
Mar 17th, 2010
I have an access switch. the interfaces don't have the command "switchport mode access" on them. What is the impact when PCs are connect to these ports?
glen.grant Wed, 03/17/2010 - 10:26
  It won't have any effect , by default its probably dynamic desirable which means if you stick another switch on the other end it is going to try and create a trunk link automatically but if you connect a pc  it will work normally . That being said  if its only going to be user pc's on the port you should make them all switchport mode access.
