AIP-SSM interface
Answered Question
Mar 17th, 2010
What does the interface configuration in AIP-SSM indicates ?
If this indicates that the traffics of this interface will be monitored, then what is the purpose of diverting traffic from asa though policy command.
Correct Answer by Jennifer Halim about 6 years 7 months ago
Thanks, hope i've answered your questions.
Overall Rating: 5 (1 ratings)
Jennifer Halim Wed, 03/17/2010 - 15:14
The external interface of the AIP-SSM module is purely for management (Command and Control interface). You would need to connect that to your network so you can manage the module (IDM).
uthayaman Mon, 03/22/2010 - 02:16
I understood the AIP-SSM mgmt interface ip configuration.In the setup mode when we configure the aip ssm what does the below option represent.
Modify interface/virtual sensor configuration?[no]: yes
Current interface configuration
 Command control: Management0/0
 Virtual Sensor: vs0
  Anomaly Detection: ad0
  Event Action Rules: rules0
  Signature Definitions: sig0
  [1] Edit Interface Configuration
  [2] Edit Virtual Sensor Configuration
  [3] Display configuration
Jennifer Halim Mon, 03/22/2010 - 02:21
That is the command and control interface, ie: for management of the module (the ip address that you would https/IDM to).
Gig0/1 is the sensing interface, which is connected internally at the backplane of the ASA.
uthayaman Mon, 03/22/2010 - 02:23
Here , the monitored interface represent my ASA's physical interfaces ?
If i have four physical interface on my ASA, whether i need to include all the inteface under this monitored option ?
uthayaman Mon, 03/22/2010 - 02:32
Thx for the reply....
In which cases i have to change the interface settings.
uthayaman Mon, 03/22/2010 - 03:09
under which condition i need to change this interface configuration, if this gig interface is the internal one.
Jennifer Halim Mon, 03/22/2010 - 03:12
Unfortunately for the AIP-SSM module, you are not able to change any of the interfaces.
uthayaman Mon, 03/22/2010 - 03:40
But i got the option to add interface while configuring aip-ssm.Since i was not clear i didnt make a
ny change and came out of the configuration.
Jennifer Halim Mon, 03/22/2010 - 03:44
Because you choose "yes" to modify the configuration while going through the process:
You can modify the management interface, ie: unassign it, and modify the sensing interface settings. However, you can not swap, or delete those interfaces.
uthayaman Mon, 03/22/2010 - 03:55
Thanks for your valuble time!!!
I did the same what you have mentioned.What will happen if i change the se
nsing interface(adding three sensing interfaces).Will it affect any performance.
Jennifer Halim Mon, 03/22/2010 - 04:15
Unfortunately you can't add anymore sensing interfaces on the AIP module. There is only 1 (gig0/1) of the module which is connected through the backplane of the ASA.
Here is how you configure traffic to be redirected towards the module from the ASA:
Note: You can only direct traffic to be inspected by the AIP module from the ASA. There is no other way.
uthayaman Mon, 03/22/2010 - 04:19
Thanks for the clarification...
I will re do the configuration and let you know.
uthayaman Sun, 03/28/2010 - 04:39
I did the change and it is working fine.
I want to upgrade the image of my AIP-SSM.I am using aip-ssm-40.Can you suggest which version i can use and steps to upgrade.
Jennifer Halim Sun, 03/28/2010 - 16:26
I would suggest an upgrade to the latest version which is 7.0.2(E3). You can upgrade directly to that version if you are currently already running at least 5.1.6(E3).
To upgrade:
1) Download the upgrade package:
2) Go to IDM: Configuration --> Sensor Management --> Update Sensor --> upload the upgrade package from your local computer and update it.
Hope it helps.
Related Content
