Ip communicator and SnR
michaeljbyrne
Ok.
I have a remote user and she uses a softphone. Obviously if the softphone is un registered snr will not work. Is there a way around this? I knoiw CFall is an option.
Aaron Harrison
Try Call Forward Unregistered?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Jaime Valencia
I'll assume you have CUCM  6.x at least, why not configure the CFUR to the user's mobile??
If IPC is not registered, calls will go to the CFUR destination.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
