03-17-2010 01:57 PM - edited 07-03-2021 06:37 PM
In some of our facilities, I'm able to see the AP name in my survey tool of my 792x phone. Yet in others, I only see the MAC address. Am I missing a WLC configuration somewhere that allows this to appear on my phone?
03-17-2010 02:32 PM
Define "others"? The Site Survey tool of the 7921/7925 is limited to the SSID the phones are configured to go. If you, for example, use the 7921/7925 tool to survey the local supermarket they won't see it unless the SSID they were configured are not there.
03-17-2010 02:39 PM
Thanks for the reply. Functionally, the phone works throughout the entire building and I'm only referring to 1 internal SSID used by the phones in my scenarios described below.
We have a multi-floor building. One some floors of the building, while using my 7925, I'm able to view the AP name. Yet - on other floors of the same building, I see only the AP MAC address.
We have floors mapped to specific WLCs. So floor 1 will be mapped to WLC 1, floor 2 will be mapped to WLC 2....etc. So it must be a setting with the WLC that publishes the AP name to the phone.
02-06-2011 11:53 PM
Need to ensure Aironet Extensions is enabled in the WLC/AP config.
