Configure Etherchannel on LACP configured module on 6500
Mar 17th, 2010
I setup a blade on my 6513 to use lacp for my SAN using the channelprotocol command. I now
need to setup an Etherchannel on the same blade between 4 ports but I get the error that it is configured as LACP. Is there any way to set specific
ports back to pagp so I can setup an etherchannel on these ports or do they need to go on a separate blade. I need etherchannel v.s. LACP because VMware ESX doesn't support LACP.
Lei Tian Wed, 03/17/2010 - 19:14
Hi Greg,
If the 6500 is running native mode, you can configure lacp or pagp per port base.
Lei Tian
Lei Tian Wed, 03/17/2010 - 19:30
If you are running CATOS, then it is not native mode. In catos, you cannot have different protocols running on same module.
Lei Tian
