Aaron Harrison Thu, 03/18/2010 - 01:52
  • Community Spotlight Award,
    Member's Choice, May 2015
Certainly - usually you would have one directory number on the Fax (use the one it should display for outbound CLI), and then create a translation pattern to map the other DDI to that directory number.
Aaron
Please rate helpful posts..
