How to configure two independent SHDLS connections through one HWIC-2SHDSL?
Mar 17th, 2010
Hello!
I've been collecting information on principles of SHDSL connection. I have found plenty of examples on how to configure only one SHDSL link. Very soon I'm going to the site to install two independent SHDSL links in Cisco 2811 which has one Cisco HWIC-2SHDSL module, so I can route one type of traffic through one connection and another type of traffic through another. Both SHDLS links have static IP addresses and probably different VPI/VCI values.
Can anyone help me with a sample configuration or give me a hint on how to install two SHDSL links into one HWIC-2SHDSL module, set one value for VPI/VCI on one link and another value for VPI/VCI on another link, also set one IP address on one link and another IP adddress on another link?
Overall Rating: 4.5 (2 ratings)
Konstantin Dunaev Thu, 03/18/2010 - 01:17
  • Bronze, 100 points or more
just to be sure, are you talking about single HWIC-2SHDS in 2811? is yes, then it's  only one port SDSL module which is using 2 pair of wire.
if you need 2 independed SDSL connection then it's more simple and may be cheaper to use two external SDSL modem and configure PPPoE.
But you need additional Ethernet port for your 2811, or may be 4-port switching module.
Sergei Vereshchagin Thu, 03/18/2010 - 22:11
Two external SDSL modems are already in use and they are going to be removed. Instead of them HWIC-2SHDSL module was planned to be used with the purpose to eleminate additional points of failure and the ability to debug.
By saying "if yes, then it's  only one port SDSL module which is using 2 pair of wire", do you mean that the single HWIC-2SHDSL module can't be used for two independent 1 pair of wire connections and can only be used for only one connection on 2 pairs of wire, the only benefit of which is increased speed?
Paolo Bevilacqua Fri, 03/19/2010 - 04:17
  • Hall of Fame,
    Founding Member
What makes you think it can be used in the way you imagined ?
Sergei Vereshchagin Fri, 03/19/2010 - 04:31
The description of the product in Cisco Price List :
HWIC-2SHDSL - 2-port G.shdsl HWIC
What else should I think if I see the phrase 2-port. Logically, I assume that I can use one port for one Internet connection and another port for another connection or load balance between them or do with the ports whatever I imagine to do, like I can, for example, with this module "HWIC-2FE= - Two 10/100 routed port HWIC" which also says 2-port. The only difference for me is that one supports DSL and another Ethernet.
Am I misled?
Sergei Vereshchagin Fri, 03/19/2010 - 23:35
And I am reading: "the 2-pair G.SHDSL HWIC provides two ports of 2-wire or one port of 4-wire connectivity options".
Sergei Vereshchagin Sat, 03/20/2010 - 11:25
Thanks, I had suspicions that by creating a DSL group a corresponding ATM interface will appear and if I create two DSL groups this action will provide me with two ATM interfaces to configure. I just wanted to make sure. Soon I'm going to implement this at client's site and see how it works.
Konstantin Dunaev Fri, 03/19/2010 - 04:52
hmm, I think it is not  possible to configure two logicaly independent (like 2 virtual interfaces) connections. It will be provided only increased speed and some kind of failover between 2 pair of wire.
If you find out the way how to configure it, I'd be glad to hear it
bchostner Tue, 12/14/2010 - 09:49
I am working on an HWIC-2SHDSL POC in Germany now and I have worked this out through trial and
error, you may use pair 0, pair 0-1 or pair 1. This is the configuration. You see it creates a second ATM interface to be resourced with any logical config you like, virtual or dialer.
controller SHDSL 0/0/0
dsl-group 0 pairs  0
dsl-group 1 pairs 1
sh run | be ATM0
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/1
no ip address
sh controller shdsl 0/0/0
should show group 0 and group 1 status up.
I dont have this working yet, but I will. best of luck.
Brian
Aleksei.Zjabkin Wed, 12/21/2011 - 04:34
Privet Sergei,
Did you have completed your configuration? Do it work?
I'm planning to do the same configuration with my HWIC-2SHDSL. And it would be great to hear from, that it works.
Aleksei
bchostner Wed, 12/21/2011 - 06:35
Aleksei,
I never deployed two SDSL to the same router, we only did a single SDSL in our testing. I think the configuration is based on annex G and would greatly depend on your providers equipment, so they may be able to provide some configuration assistance.
This was my configuration for a single 512k SDSL with DT.
dsl-group 0 pairs  0
  shdsl rate 576
interface ATM0/0/0
bandwidth 576
no ip address
load-interval 30
max-reserved-bandwidth 100
interface ATM0/0/0.1 point-to-point
ip unnumbered Loopback10
pvc 1/51
  vbr-nrt 576 576
  tx-ring-limit 5
  encapsulation aal5mux ppp Virtual-Template1
interface Virtual-Template1
bandwidth 576
ip unnumbered Loopback0
load-interval 30
no peer default ip address
ppp multilink
ppp multilink links maximum 1
ppp multilink endpoint hostname
service-policy output WAN-EDGE
Sorry I could not be more help.
Brian
Aleksei.Zjabkin Wed, 12/21/2011 - 08:56
I see you have used here only one pair of your's two pair interface.
I think it is possible to do the same config with two dsl-groups...
Aleksei
