Unity Express downgrade question
Answered Question
Mar 18th, 2010
We have a customer who has ordered an NME-CUE running Unity Express 7.x (I am not sure whether it will have 7.0 or 7.1 installed). We have just found out that they are running CallManager 4.1(3) (I will be talking to them about upgrading this soon) which according to table 2 in the compatibility matrix at the link below will not work with Unity Express versions later than 3.1.2
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
3.1.2 looks like it should be ok for the customer once they upgrade their IOS to 12.4(9)T (currently on 12.3) as the NME-CUE will work in their 2851 with this version.
My question is to do with downgrading the version of Unity Express from 7.x to 3.1.2. The 3.1.2 software is still available for download. Will it be as simple as doing a clean install via FTP and then installing the correct language pack or will there be any issues with license files? I have not done much with Unity Express recently so I am a bit rusty on how things like licenses work.
thanks
James
Correct Answer by Brandon Buffin about 6 years 11 months ago
Yes, a clean install should do the job. Prior to 7.1, CUE licensing was on the honor system, so you should be able to download the license that you need.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Thu, 03/18/2010 - 05:27
Hope this helps.
Brandon
Related Content
