WS-C4948-10GE TwinX SFP Support
Answered Question
Mar 18th, 2010
Can anyone confirm whether or not the WS-C4948-10GE switch supports the TwinX converter modules to allow the use of the 1000Base-X SFPs ?
The data sheets state clearly that only the X2 optics are supported for 10GE fibre uplinks, yet the release notes for version 12.2(50)SG state that the new hardware feature, "SFP+ using the X2 hole adapter" is supported.
Any help is much appreciated.
Chris.
Correct Answer by Giuseppe Larosa about 7 years 4 months ago
Hello Chris,
it looks like unsupported in the datasheet
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps6230/product_data_sheet0900aecd80246552.html
see table-2 at the line "TwinG support" it reports No
configuration guide that is shared with C4500 says:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/52sg/configuration/guide/sw_int.html#wp1128472
To use an SFP+ in an X2 port to obtain 10-Gigabit  Ethernet bandwidth, the Catalyst 4500 series switch supports OneX  Convertor modules. When you plug a OneX Converter module into an X2  port, it converts the X2 port into an SFP+ port into which you can plug  in an SFP+. An SFP+ in a OneX Convertor module provides the same  functionality as an X2 and maintains the same port numbering.
This feature is supported on Supervisor Engine 6-E  X2 ports as well as the WS-X4606-10GE (or WS-X4606-X2-E),  WS-X4908-10GE, WS-X4904-10GE, and WS-C4900M chassis.
It makes sense for a data center switch like this to support only 10GE uplinks
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 03/18/2010 - 05:39
  • Hall of Fame,
    Founding Member
Hello Chris,
Hope to help
Giuseppe
cbeswick Thu, 03/18/2010 - 06:13
Thanks Giuseppe. I missed the line in the table.
