nseto Fri, 03/19/2010 - 10:11
  • Silver, 250 points or more
No, the LAN side is fixed and is only to be used for direct connection from a pc to the aux port for config purposes to the unit.
jhclemente Thu, 01/06/2011 - 09:37
I need to change this configuration because I have various vlans in my network and it's conflicting with my 192.168.0.0/24 segment.
Can it be changed?
