ICM 7.0 - Sprawler database tables not updating
Answered Question
Mar 18th, 2010
I have setup  ICM 7.0 Sprawler  in lab environment.
I can login agents successfully , Agents receive calls via Route point etc. but unfortunately, the database tables like t_Agent_Skill_Group_Real_Time , t_Agent_Skill_Group_Real_Time (AWDB ) are not updating.
Please can anyone advise what checks I can do to find out the issue? I checked the services windows for any errors but couldn’t see any relevant info .
Many thanks,
Srinivas
Correct Answer by geoff@hp.com about 7 years 4 months ago
That name can be absolutely anything - just make them match up. When you create the AW and it asks you for a site name, enter FOOBAR and then make the Agent Distribution the same.
The default install of the AW initialises this field to the name of the box. If you use that in the Agent Distribution Site Name, it will align.
I'm not certain that this is the solution, but you should have these match. Look at the Pre-Installation Planning Guide on page 10-5 to get an explanation of "Admin Sites".
Geoff
Overall Rating: 5 (2 ratings)
e.gailiss Thu, 03/18/2010 - 06:42
I remember I had this problem..... If I remember correctly, it was that in PG config (in Configuration Manager) I used IP address of AW (Distributor) where hostname should have been. Since you are doing lab setup... do you use host names in config or just IP address?
Ervins
e.gailiss Thu, 03/18/2010 - 07:59
Try using hostames in PG config in Peripheral configuration Agent Distribution tab in Configuration Manager->PG Explorer. I think it will solve your problem.
Ervins
Correct Answer
geoff@hp.com Thu, 03/18/2010 - 08:06
  • Red, 2250 points or more
Geoff
e.gailiss Thu, 03/18/2010 - 08:18
Thank you, Geoff!
You explained why my solution worked for me. I couldn't find this information at the time. Hopefully it will work for Srinivas (original poster) also.
Ervins
bathula.srinivas Fri, 03/19/2010 - 04:46
Hi Geoff,
You are a genius. I made the changes and it worked!!
I re-ran the ICM setup for AW and entered a name instead of IP as the Distributor site name.
In the PG explorer- peripheral config - matched the Agent distribution name with the Distributor site name.
Hi Ervins,
Many thans for your post too..
Cheers,
Srinivas
