Aironet 1140
Mar 18th, 2010
Hi we just purchase 2 aironet 1140 ac
cess point
We configure both of them as access point and put one on the first floord and the second one the the second floor
Is there a way in windows client to tell windows to use the best wifi access point (the best signal) ?
If not is it better to confirure one as a repeater ?  Ive read that setting an access point as a repeater will drastically reduce throughput...
Any suggestion on how should i use these 2 access point ?
Thanks !
dancampb Thu, 03/18/2010 - 08:46
You want to configure the same SSID on both APs and the client will automatically pick the AP with the better signal.
ciscoblainville Thu, 04/01/2010 - 13:16
Ok thats a good idea but
let say for exemple
Client1 connect to AP1 at first floor...
Then he move and go to second floor...
It will not switch automaticly to AP2 ?
Client have to disconnect and the reconnect right ?
Thanks !
Leo Laohoo Thu, 04/01/2010 - 15:34
There are a number of reasons whether or not the client will associate to a specific AP and not to the closest one:
1.  Signal strength, SNR;
2.  Client drivers
Check the signal strength of the APs from different floors.  You can either lower the transmission signals or moving the APs might help.  Another is disabling some of the lower MCS rates.
