WLAN Controller 4404
Mar 18th, 2010
We recently acquired a 4404 Cisco controller for our network and have been adding our 1200 and 1130 Access points to the controller.
This was accomplished by uprgading the APs to LWAPP and then they would automatically be discovered by the controller and then join. Lately, new 1131 APs that have undergone the same process, are not joining the controller. They are discovered but then the close the connection. We are running a flat network so all devices are in the same subnet.
Software Version of the controller 6.0.188.0
Here is the log from the AP:
*Mar 12 18:56:23.411: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully17e420.18fromrollerOVERYNregulations. If you are u
ion.
*Mar 12 18:56:49.413: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.0.0.18
*Mar 12 18:56:49.413: %DTLS-5-PEER_DISCONNECT: Peer 10.0.0.18 has closed connect
ion.
*Mar 12 18:56:49.413: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 1
0.0.0.18:5246
*Mar 12 18:56:49.414: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Mar 12 18:56:48.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 10.0.0.18 peer_port: 5246
*Mar 12 18:56:48.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Mar 12 18:56:49.409: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
peer_ip: 10.0.0.18 peer_port: 5246
*Mar 12 18:56:49.411: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.0.18
*Mar 12 18:56:49.411: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Mar 12 18:56:49.415: %DTLS-5-ALERT: Received WARNING : Close notify alert from
10.0.0.18
*Mar 12 18:56:49.415: %DTLS-5-PEER_DISCONNECT: Peer 10.0.0.18 has closed connect
ion.
*Mar 12 18:56:49.416: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 1
0.0.0.18:5246
*Mar 12 18:56:49.470: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 12 18:56:49.481: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
- Show quoted text -
Leo Laohoo Thu, 03/18/2010 - 14:19
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Paul,
The 6.X firmware has significantly improved how the the AP discovers a WLC.  Have you tried to console into the AP in question the command "config lwapp ap controller "?
How many APs are already associated to the WLC and how many AP can your WLC support?
Try to clear the config of the AP by using the command "clear lwapp private" followed by "clear lwapp ap controller ip address" and then reboot the AP
williampenn Thu, 03/18/2010 - 15:12
Thank you for your reply.
The issue has been solved. It acutally involed making another ap manager. There is only so much APs per management port.
George Stefanick Sun, 03/21/2010 - 18:23
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Correct, each port / ap manger can handle 48 aps. If i can ask, why arent you using LAG?
fbarboza Fri, 08/10/2012 - 08:05
  • Bronze, 100 points or more
Hi ,
If you enable LAG and have several ports of the WLC connected to the same switch and enable loadbalancing on the WLC then you just need one AP manager configured but if you are not using LAG since each port supports up to 48 Aps then you will need to configure several AP managers and link each AP manager interface to a port.
Also check on this link under Scaling the 440x WLC Beyond 48 Access Points
http://www.cisco.com/en/US/docs/wireless/technology/controller/deployment/guide/dep.html#wp1061736
Related Content
